Bosch WFK2200GB
  • #33042
    philipday
    Hello
    Our normaly reliable washing machine has stopped working. I suspect it tripped the house fuses as it failed.
    Model is WFK2200GB / RFD 7612 00480
    Error 4 is shown.
    This error is not described in the booklet, so I ma hoping that some one will know what the error means and which parts would be required to fix the machine.
    Many thanks
    #237222
    gegsy
    Re: Bosch WFK2200GB
    Hi error 4 is connected with motor rotation, or probably lack of it 😉
    If its blown the trip you may have motor damage. If you turn the drum by hand, do you hear a definate clicking sound??
    philipday
    Re: Bosch WFK2200GB
    Thanks for your reply.
    I jumped in and did a bit of my own R&D, and found that
    Error 4 is indeed drum motor related.
    The carbon brushes are fairly worn – 8mm remain
    So I went ahead with ordering some new brushes and replacing them. The motor is running again now, but I did not notice any clicking noise. I will go and check for this later when I get home.
    The only slightly disturbing thing is a smell which comes from the motor and reminds me of the days I spent playing with Scalextric cars. I am hoping that the smell is one of 2 things. The new carbon brushes bedding in. Or old carbon dust getting burned off. I decided to clean the motor by blowing hard in throgh the various vent holes. (Very scientific I know).
    I did the brushes at about 11pm last night, so the machine was not used straight away. But, by the time I get home the machine will have been used and I will have a better idea if things are working.
    #237224
    Re: Bosch WFK2200GB
    philipday wrote:The new carbon brushes bedding in. Or old carbon dust getting burned off. I decided to clean the motor by blowing hard in throgh the various vent holes. (Very scientific I know).
    You have to hope first off all that you have put the brushes in the correct way round (i.e. the angled taper of the brush only fits one way- that’s assuming it’s a Siemens motor in this case and not an FHP motor of course?). And it would always be a safe option to run-in the brushes with an empty machine on a couple of slow spin (minimum spin) cycles. Without a full strip-down and clean of the motor you will experience some form of early signs of arcing. You have to hope it settles down very quickly during the running-in period to avoid permanent damage to the armature? 😕
    #237225
    philipday
    Re: Bosch WFK2200GB
    Thanks for the advice Martin. I did know that the brushes had a correct way round, and I am certain that I put them in correctly. Thinking about it you have to be pretty thick not to notice the 45degree angle on the business end of the brushes. 😀
    I have turned the drum and there is no obvious clicking sound from the motor/comm but … the machine is pushed back into its housing and the back panel is screwed on again, so it is possible that I may have missed a small sound.
    If the motor is damaged in some way – (after all something made the circuit breaker on the power side trip) what normally happens to washing machines. New motor, existing motor re-conditioned, machine scrapped ❓
    On the basis that the machine is running OK for now, following the £10 investment in brushes, i think I will leave it be. It will either run happily for a while giving more good service, or it will fail again soon and the real problem will manifest itself again.
