Bosch WFK2201:re-fills after wash cyle complete
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WFK2201:re-fills after wash cyle complete
  • #54032
    Doogs
    My In-laws Bosch WFK2201 washing machine has developed a fault whereby after the wash cycle has completed,it will then re-fill with water.
    Can anyone give some pointers as to the likely cause and are parts still available for this model?
    thank you.
    #318121
    odom
    Re: Bosch WFK2201:re-fills after wash cyle complete
    Can you explain the problem a bit more? The machine is meant to refill with water three time after wash to rinse the clothes (sorry if that sounds obvious!).
    We need to know what is happening – e.g.
    After wash: –
    Drain pump on
    Spins out water
    Thanks.
    #318122
    Doogs
    Hi Odom.
    The way it was explained to me was this:
    The machine will wash,then rinse cycle then spin as per usual,however,once it has stopped if you are not quick to remove the washed clothes,it will start another rinse cycle.
    #318123
    CJAPeterborough
    just a thought but does this model have a “rinse plus” button if so has this been set by mistake?
    #318124
    It’s an early digital machine – it more or less has to be a logic error, so you’ll need a power board – a snip at £249.81.
    Doogs
    Thanks for your replies guys.
    I did see a extra rinse button,so I will ask the in-laws if this is on.
    If it is the power board as Penguin suggests,would it be worth fixing?
    It was a reconditioned machine,bought as a stop-gap about 4 years ago.
    Doogs.
    #318126
    Er, no….
    Doogs
    There is an extra rinse button,but they don’t use it. So its off to that appliance showroom in the sky.
    Many thanks for the replies once again.
