Bosch WFK2801 – outlet blocked?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WFK2801 – outlet blocked?
  • #34126
    planetf1
    I have a ~8 year old Bosch front-loading washing machine, model
    WFK2801. It’s been working fine until this weekend when I (stupidly)
    put 3 small squares (perhaps 30×30 cm) or carpet in.
    During the low temp (30 C) wash lots of fluff/fibre came out of the
    carpet. After completing the cycle I picked up the pieces of yarn
    inside. I also cleaned the small amount out of the drain filter.
    Today the wash stopped with error 3 – blocked outlet. I restarted
    manually, and it drained, just a bit slowly. I did a 90 C wash with
    some soda crystals (done many times before) to soften up any gunk/
    limescale, and after this I again checked the filter, and also took
    the opportunity to clean out the “trap” between the pump and rear of
    machine – A piece that is often limescaled up.
    It wasn;t too bad. The drain hose looked ok at the sink end, and no
    blockage in the sink. I did not however remove/clean..
    Just done another wash and the machine is really struggling to drain –
    basically it won’t!
    – I;m pretty sure the pump is operating
    – it starts emptying slowly (higher pressure in drum?) and then slows
    to a crawl
    – Some water comes out of the front/emergenvy drain hose connected to
    pump, but not a huge amount
    – When the pump operates water stops coming out of the short/front
    emergency hose
    – When the machine is powered off a glassful or so rapidly comes out
    this same hose then slows to a trickle
    – If the screw-cap over the pump/filter is removed water comes out
    slower than expected?
    Tomorrow I plan to (obviously) remove/clean the hose from machine rear
    to drain.
    I think I also need to check the one between the “trap” and the pump –
    hope it’s not too hard, not done that one before
    What else could it be/should I check? How easy is it to get to the
    pump to clean? Should I detach the pipe from the drum? Is it hard to
    get to/reattach? Is best way to remove all the pipes from the pump+ drain from drum to remove front panel? Is that fairly obvious to do?
    Many thanks for the advice. Just preparing for a “session” tonight 🙁
    Nigel.
    (feeling a bit stupid right now……)
    #241386
    Re: Bosch WFK2801 – outlet blocked?
    Are you sure the blockage is in the machine and not the house plumbing? I would try having it draining into a bucket and see if it empties quicker.
    #241387
    planetf1
    The hose attaches to the sink plumbing. The sink drains extremely rapidly, so at worst the host from machine to sink could be blocked.
    I couldn’t check that last night — plan to tonight. Was just prepping for different eventualities.
    My gut feel is it’s internal, since attempting to drain from the pump area (via the access/hose at the front results in a surprisingly slow outflow of water).
    Could be pressure but I doubt it..
    Thanks for the reply
    — Nigel.
    #241388
    planetf1
    Did the deed (mostly) last night. Recommendation was access via front panel. access was pretty easy and one pipe was virtually blocked solid in limescale (+fluff and 5p coin!). Apart from one screw which needed penetrating oil to soak!
    All done apart from the outer door seal to attach which needs a second pair of hands – and will prob be somewhat tricky.. think bicycle tyre. And of course testing …..
    Other than 2 pairs of hands and soap, any recommendations for remounting the outer seal? The clip is actually just a solid wire (think coat hanger) attached with a very tight spring. It seems the best bet is to slide on with clip mounted, starting at the spring side, but it still seems very tricky
