BOSCH WFK2801 with FHP motor – which brushes?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum BOSCH WFK2801 with FHP motor – which brushes?
  • #86214
    aris
    I need to change the brushes on a Bosch WFK2801 – but note there are different motors and different brushes for these.
    Am I right in saying that the standard brushes like these which are listed for the wfk2801 will not work?
    http://shop.ukwhitegoods.co.uk/bs12103- … on-brushes
    I’ve not taken the unit out to have a look but did see from the outside that it is an FHP motor:
    http://i.imgur.com/BoGnQYc.jpg
    Which brushes do I need?
    I did see these:
    http://shop.ukwhitegoods.co.uk/167517-w … on-brushes
    With note saying to look at these as a low-cost alternative:
    http://shop.ukwhitegoods.co.uk/ag12103- … or-brushes
    This low cost alternative doesn’t mention the WFK2801GB/01 though – in fact it doesn’t mention Bosch at all.
    Thanks in advance
    #430557
    Re: BOSCH WFK2801 with FHP motor – which brushes?
    aris wrote:http://shop.ukwhitegoods.co.uk/ag12103-fhp-washing-machine-motor-brushes
    They will fit your Bosch OK. 😀
    #430558
    aris
    Cheers for the reply on a Sunday Martin – i’ll order a set then 🙂
    Are these difficult to fit compared the the other type with the external springs?
    #430559
    Very easy to fit.
    #430560
    aris
    Martin wrote:Very easy to fit.
    Too right 🙂 This is a lovely machine to work on.
    So i’ve got them in – it is spinning. The old brushes were about half a centimetre long!
    I am getting a bit of a whine from the motor now – i’m assuming this is the brushes bedding in? I did clean the com with an old toothbrush – it seemed fine, little bit of carbon came off. If it is just bedding in, how long should it take? I’m putting it on multiple spin cycles to see if the noise settles down.
    #430561
    Several low speed spin cycles are best. Don’t be tempted to put it on full warp speed until they have bedding in. 😉
