Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch WFK2801GB/01
- This topic has 9 replies, 7 voices, and was last updated 20 years, 4 months ago by
Bryan.
November 18, 2005 at 7:34 pm #13419
Bryan
ParticipantAccording to customer this machine works perfectly as normal except at the end of the cycle , instead of the display going to “0” and the door interlock releasing , the display stays at “1” and the only way to open the door is to switch machine off. The interlock then releases and door can be opened.
Is this an electronic fault or perhaps the door interlock or any other ideas ❓Thanks
Bryan
November 18, 2005 at 8:40 pm #154784Penguin45
ParticipantRe: Bosch WFK2801GB/01
Pressure switch? Won’t unlock if it thinks it’s got water in?
November 18, 2005 at 9:03 pm #154785leavemetogetonwithit
I had this one a while back.
I remember tracing it to being a timer fault.
Lot cheaper just to switch off and wait.
Mike.November 19, 2005 at 8:38 am #154786Martin
Bryan wrote:Is this an electronic fault or perhaps the door interlock or any other ideas
Draining ‘time out’ is the most usual cause (i.e. Clogged up Vented Drain Container etc) very often several minutes may show on the display too 😉
November 19, 2005 at 9:19 am #154787Bryan
Thanks for the replies guys but this machine functions normally other than door interlock not releasing at the end and “1” in the display.
I would have thought pressure switch or water draining problems would have resulted in fill/spin problems 😕The customer is doing as Mike suggested and simply switching power off to open door and washing is perfect.
Bryan
November 19, 2005 at 9:39 am #154788Martin
Sorry Bryan, Chris and I assumed you were just enquiring before you actually went to look at it yourself, as customers often can give misleading information after all.
I could have sworn it was a time-out fault, ah well 😕
November 21, 2005 at 12:26 am #154789sparkey
Have you checked for heater down to earth ❓ , many Bosch machines of this series will stay locked although the cycle has finished.
Regards
SparkeyOctober 11, 2010 at 11:45 am #154790allan73
Hi Bryan, I realise this was some time ago but did you ever resolve this as I have the same model with the same fault ?
Allan.
October 11, 2010 at 12:00 pm #154791Martin
allan73 wrote:Hi Bryan, I realise this was some time ago but did you ever resolve this as I have the same model with the same fault ?
Check the coils on the cold valve. 💡
October 11, 2010 at 3:25 pm #154792RickT
I’m with sparkey on this one , heater earthing fault
