Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch WFL 2000 Washing m/c
- This topic has 6 replies, 5 voices, and was last updated 20 years, 7 months ago by
admin.
August 28, 2005 at 10:16 am #11629
KeymasterProblem: Machine occasionally will complete the cycle but invariably just continues to wash until it is stopped and the spin cycle is sellected.
Any quick fixes?
August 28, 2005 at 1:55 pm #146063Del
ModeratorRe: Bosch WFL 2000 Washing m/c
First things first, have you gone through the trouble shooter guide in your instruction booklet for the machine ? i.e. checked for blocked filters, kinked hoses, water supply etc.
If so how long does it stay on for on say a colourfast 40 degree, wash as these machine do have long wash times.
Have you tried doing a maintinance wash at 90 degrees with the machine empty and a small amount of detergent to desludge the machine.
TRY these first
HTH
Del
August 28, 2005 at 7:26 pm #146064superfix
ParticipantRe: Bosch WFL 2000 Washing m/c
Sounds like you have selected “rinse hold” program to me.
August 30, 2005 at 12:18 pm #146065admin
KeymasterRe: Bosch WFL 2000 Washing m/c
Del wrote:First things first, have you gone through the trouble shooter guide in your instruction booklet for the machine ? i.e. checked for blocked filters, kinked hoses, water supply etc.
TRY these first
HTH
Del
Afraid no manual available. Have checked all the obvious filters, H&C inlet (both ends) and main pump inlet, all clear.40 degree wash would normally take approx 45 mins. Occasionally this works but we have had it running for hours without going into the rince/spin cycle. We have resorted to timing the wash period, stopping it and sellecting rince, it then completes the wask OK. The ‘rince hold’ button been tried and the acknowledge light switches on and off and has not been sellected.
We have done a 90 degree wash with a proprioty descaling compound with no apparent change.
Anything else we can try?
August 30, 2005 at 12:29 pm #146066Goatboy
Is it getting to the rinses, or sticking on wash?
What is it doing for hours when it sticks?
August 31, 2005 at 3:28 pm #146067admin
Goatboy wrote:Is it getting to the rinses, or sticking on wash?
Machine appears to be stuck on the wash cycle and rotates/counter-rotates for as long as we let it?
August 31, 2005 at 3:41 pm #146068 -
