Bosch wfl 2260
  • #51342
    bugsy
    This has been a great machine for around 10 yrs but I think the drum bearings are on their way out.
    Any tips on replacing them? I am an engineer but not for white goods.
    Any advise appreciated or would I be better replacing the macine?
    Regards
    #307703
    Re: Bosch wfl 2260
    Bearing and seal kit is HERE.
    The bearings are in the cross-piece on the rear of the tub. 9 bolts and it pulls off.
    A big hammer and stout steel bar are essential equipment for the next bit….. Work gloves and eye protection sre also a good idea.
    Power off first, of course.
    bugsy
    Re: Bosch wfl 2260 Drum Bearings
    Thanks for the reply. I can’t see the part you refer to. If I look under the pully I can see the outer bearing, nothing else! Looks to me like the inner bearing is inside the drum. If that’s the case I guess it’s a pretty awkward job?
    I ask myself if it’s worth reairing or not?
    Regards
    #307705
    Re: Bosch wfl 2260
    Take the crosspiece off…..
    bugsy
    Re: Bosch wfl 2260
    Thank you again for your advise. I still don’t see this…… downloaded a diagram from the Bosch web site which shows something like you describe (but with three legs) only it is not on the outside by the pully but otherside in the drum. I assume these drums come apart for access to these bearings.
    Maybe my vague model no has confused? Full model is Bosch Maxx WFL2260UK/01. Could it be as you described on a 2260UK/XX? Thanks in anticipation
    #307707
    Re: Bosch wfl 2260
    Right – that version has the two part “clam shell” tub and uses THIS BEARING KIT.
    It now becomes a complete and total evil swine of a job. Tub must be removed and split to allow access. As a repairer whose done this before, I can do it in about two hours. If it’s your first time, I’d allow Sunday for the job.
    Sorry about the confusion.
    bugsy
    Re: Bosch wfl 2260
    Thanks again for your prompt help and sorting out my confusion!
    I might still give it a go as otherwise machine seems good and from what I have read on here, some of the new models around now leave a lot to be desired. I’ll wait for the snow to go, get it outside and give myself a weekend.
    Thank you again
