Bosch WFL 2260 drain pump
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WFL 2260 drain pump
  • #17999
    Bishbashbosch
    After sludge & scale from the drain pipe caused the drain pump impeller to fall off, I’m having problems with it falling off regularly. The pipes are clear of any scale – it seems that the impellor is a pushfit onto the shaft & is too lose. Can I get a new impeller or is the only fix a new pump assembly?
    #177333
    Re: Bosch WFL 2260 drain pump
    Yup, pump time – Bosch’s own pump is p/no 144305 – about £48 plus VAT, p+p etc. Or you can get exactly the same thing here:
    http://www.ukwhitegoods.co.uk/modules.p … cts_id=412
    At a rather more sensible price, in a nice brown box. 😀
    Once the impellor’s been knocked off, it will never go back on properly……..
    Dave_Conway
    Nearly…..
    :wave: 😆
    #177335
    :wave:
    #177336
    Bishbashbosch
    Thanks for the speedy reply! Should be getting my pump tomorrow – looking forwards to smelling fresh again…
    #177337
    Dave_Conway
    Out of interest, where did you get one from in the end ? 🙂
