Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › BOSCH WFL 2260 NOT DOING ANYTHING!!! HELP!! PUMP BROKEN?
- This topic has 14 replies, 6 voices, and was last updated 19 years, 2 months ago by
intimidator.
February 9, 2007 at 10:27 pm #24927
intimidator
ParticipantIt started making a terrible noise when spinning so I removed a bra wire that was stuck in the impeller. The impeller turns ok by hand.Now the pump is making a low buzzing noise but nothing is working. It seems to fill with water ok if I start a cycle but if I turn it to ‘spin’ or to ‘rinse’ it just buzzes. Has the pump burnt out? If so is it easy to repair and how much would it be? 🙁
February 9, 2007 at 10:33 pm #203843helo_75
ParticipantRe: BOSCH WFL 2260 NOT DOING ANYTHING!!! HELP!! PUMP BROKEN
u sure theres nothing else in there?
if its buzzing, its either something jammed in the impellor, or the pumps damaged
unplug ifyour gonna have a poke around
February 9, 2007 at 10:45 pm #203844intimidator
well after i took the wire out of the front compartment, i checked to see if the impeller would still spin, it does but it has the motion of a prop plane, as in it doesnt spin freely, it goes easy then hard then easy etc!!.
February 9, 2007 at 11:30 pm #203845iadom
ModeratorRe: BOSCH WFL 2260 NOT DOING ANYTHING!!! HELP!! PUMP BROKEN
intimidator wrote:well after i took the wire out of the front compartment, i checked to see if the impeller would still spin, it does but it has the motion of a prop plane, as in it doesnt spin freely, it goes easy then hard then easy etc!!.
That is exactly how it should feel. My dad used to make model aeroplanes in the fifties and the ‘feel’ of this type of pump is just like the little petrol engines he used. If the pump impellor has a lot of side to side movement then it is more than likely time to change it.
February 10, 2007 at 12:20 am #203846Penguin45
If you would post up the full eNr number from the inside of the door, we will be able to identify the pump required.
Penguin45.February 10, 2007 at 2:34 am #203847gegsy
Not only that Mr P, he will have to look at the make aswell as to if it is a copreci or askoll?
February 10, 2007 at 11:07 am #203848intimidator
so we have decided its the pump then?
February 10, 2007 at 11:12 am #203849intimidator
the er no is WFL2260UK/04 FD 8004 606435
February 10, 2007 at 11:37 am #203850Martin
intimidator wrote:so we have decided its the pump then?
To test the pump runs OK simply select spin only with the pump cover removed. A few seconds after pressing the start button you can observe the pump impellor spinning merrily? If not, it’s either jammed or needs replacing?
February 10, 2007 at 11:55 am #203851intimidator
thanks for the info above,
i have turned the washer onto spin only, the impeller spins ok, but there is a vibration coming from it, also the impellor can be pulled forward a few mm’s, is that rifght?February 10, 2007 at 3:47 pm #203852intimidator
pump… askoll
art. 290408
mod. m50
code. 5500003078
0.2a 30w clfis that the info we require!!.
February 10, 2007 at 4:38 pm #203853gegsy
Pump if required is p/no 144484 – £42.50 +Vat and costs.
Available from spares@ukwhitegoods.co.ukGreg
February 11, 2007 at 12:18 pm #203854intimidator
Problem solved! The pump is fine because the impeller is turning.The funny noise is because there is no water in the pump. Once the machine was allowed to fill with water it all sounded normal again. Thanks for everyones help. Great service! 🙂
February 11, 2007 at 12:21 pm #203855gegsy
You mean you didnt re test it after removing debris 😕 :rolls:
February 12, 2007 at 6:55 pm #203856intimidator
yes, i re tried it after moving debris, but it still made a noise, so i quickly turned it off, incas it was burning itself out!!.
anyway all systems go…………. thanks 😆 -
