Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › bosch WFL 2260UK/04 condenser dryer
- This topic has 8 replies, 4 voices, and was last updated 20 years, 1 month ago by
rocker.
February 17, 2006 at 4:26 pm #15709
rocker
ParticipantHaving problems fixing this machine any help welcome…machine runs motor turns / heaters ect..no water going to condenser draw.tested pump ok, I am getting intermittent 240v via timer to pump is this correct….have changed timer same problem.
condenser light has now come on can anyone tell me were activation switch is suituated… thanks john.February 17, 2006 at 5:07 pm #166062Martin
ParticipantRe: bosch WFL 2260UK/04 condenser dryer
The model number you gave is not a Washer/Dryer?????
February 17, 2006 at 5:35 pm #166063rocker
Martin. this is a self condenser dryer…not washer/dryer
cheers johnFebruary 17, 2006 at 7:09 pm #166064Penguin45
Your model number is a washing machine………..
February 18, 2006 at 8:00 am #166065rocker
Penguin, you are right, put the wrong ENR No in sorry, correct No is ENRWTL5100GB/05
February 18, 2006 at 8:55 am #166066Martin
Now we have established the model number 🙄
I would think the fault is fluff blocked pump hose to the water tank? Usually they get blocked at the joint in the hose at the back or at the nozzle attached to the tank. 😉
February 18, 2006 at 9:38 am #166067rocker
Martin. Thanks for reply will check this out on monday..will let you know the outcome.
johnFebruary 18, 2006 at 9:40 am #166068gegsy
rocker wrote: I am getting intermittent 240v via timer to pump is this correct.
Yes this is correct.
If you follow Martins advice you wont go far wrong. Failing that the tube in question can be removed and checked, also I have had a ball of fluff actually restricting impeller in uplift pump. Have fun 😉Greg
February 18, 2006 at 9:56 am #166069rocker
Greg, Thanks for advice, you and Martin both feel this is the cause, I am sure you are both right as this is on thing I didnt check…Cheers John
