bosch wfl 2260uk/04 fd8102605695 pump gone?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum bosch wfl 2260uk/04 fd8102605695 pump gone?
  • #46509
    annericefan
    I have the above machine and it’s not draining. Weird noise coming from it too. How do you remove the pump from this machine. I have tested the impellor and runs freely and spins round when tested after manually emptying machine via drain hose so think it might be the motor that runs the pump?
    I have turned machine on its side and can see it’s an askoll motor that drives the pump.
    My question is how do I get the b****y thing out to check it?
    This machine is about 8yrs old and runs 3 times a day – 3 kids, 2 dogs you get the picture lol !!!!!
    I would so love anyone who could shed just a little light for me cos I’m skint at the mo and can’t afford new machine and this is my baby -I’ve only had to change carbon brushes twice and goes like new so need advice on the pump as I fear it;s Had it !!!!!!
    Thanks in millions to those who reply – Ta !!!
    Linda (15 school shirts and 6 pairs o trousers waitin) xxxxxxxxxxxx
    #289815
    annericefan
    Re: bosch wfl 2260uk/04 fd8102605695 pump gone?
    actually my father has got pump out but we think now its the supply to pump is not constant. With pump connected it starts off whirring round then stops. What could this be? My dad has gone to test the pump with constant supply going to it to see if it goes continuously. He thinks there is a fault with power going to pump ie the power is interrupted.
    any ideas guys? could this be pcb fault. Machine is 8yrs old at least and goes 3 times a day sometimes 4 every day
    ta
    Linda
    #289816
    Re: bosch wfl2260uk/04 fd8102605695 pump gone?
    Couple of points, Linda. The pump should not spin freely – it should resist then “ping” over every quarter revolution. There should be no appreciable lateral play on the impellor if you try to wag it side to side. My money would be on the pump motor simply being very tired and worn out.
    A replacement may be found HERE.
    annericefan
    thanks penguin
    pump removed and connected to mains supply and runs continuously with no problem. Volt meter connected to supply cable on machine and machine selected to drain. Voltage observed to be 230 – 240 but after a minute or less maybe voltage drops off completely.
    So what’s controlling the supply to the pump?
    Is it worth fixing and how expensive?
    Ta guys
    Lind xxx
    #289818
    helo_75
    what penguin says is correct
    its controlled by the main control board, and it aint cheap
    you should never live test , either on or off the machine, but to clarify, running the pump on the machine, and running it off are 2 different things
    just take some good advice and change the pump
    #289819
    helo_75
    oh, and ill tell you why before you come at me with ‘it runs ok off the machine’
    it will drop off after a minute cos the machine ‘fails to activate the pump’
    yes they are that clever, they know the pumps not there
    #289820
    annericefan
    thankyou so much guys.
    Think it’s time for a new machine 🙁
    I can collect from Comet a Bosch WAE24164GB tomorrow morning. Is this model ok? It’s a classix model
    Lind xx
    #289821
    helo_75
    i still think itll just be the pump
    #289822
    nomadPaul
    OK , first things first – The reason the voltage drops off after 1 minute when drain is selcted is because thats how long the drain cycle is……when the appliance is empty. It will vary if the appliance has water in it but once the machine detects is empty , it runs on for approx 60secs and then stops .
    Before you go and buy a new machine , have you checked all the hoses and drain connections to make sure that there’s no blockage anywhere ?
    The noise , without actually hearing it , could just be an aging pump that you’re now paying more attention to as you have a problem.
    In 8 out of 10 circumstances of machines i visit , its a blockage somewhere thats causing the problem
    #289823
    annericefan
    helo_75 wrote:i still think itll just be the pump
    where do i get an askoll pump then helo?
    Lind x
    #289824
    annericefan
    ok I have ordered a new pump from this site 😀 It was only 15 quid and that’s definitely worth trying right?
    Thanks for your posts – this site is brill 😀
    I’ll let you know the outcome if it was the pump after all
    Lind xxxxx
    #289825
    annericefan
    well, I ordered the askoll magnetic pump from you guys on sat and it came first thing this morning 😀
    father has put new pump in and machine is working like a dream and purring again instead of screeching 😀
    helo_75 what can I say you’re a bloody genius 😆
    Thankyou so much to all who replied – saved me forking out for new machine
    Lind
    xx
    #289826
    helo_75
    brilliant.. thanks for taking the time to feedback to us
