Bosch WFL 2450 program not advancing???
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WFL 2450 program not advancing???
  • #38182
    johnmac
    Stays on wash until manually advanced to rinse, stays on rinse until manually advance to spin, then finishes normally. Is this a PCB fault, or should I look elsewhere? Thanks.
    #257993
    gegsy
    Re: Bosch WFL 2450 program not advancing???
    When you say manually advance, do you turn selector to 12 oclock (off pos) and then re select rinse?
    Does it heat in the wash? (feel the glass during wash cycle )
    johnmac
    Selector is moved clockwise from 30degC, to rinse, without going to “off”. It is heating.
    #257995
    gegsy
    If you just do a rinse cycle, does it complete through to the spin than end?
    If so it maybe an NTC or module fault 😕
    johnmac
    Now my wife tells me that it works perfectly if she doesn’t use the quickwash option. Problem solved – I asked her to stop using quickwash!
    (sounds like a controller fault doesn’t it)
    #257997
    gegsy
    Sure does 😀
