The machine is unplugged from the socket. Please advise me how to change this heater. I’ve carefully got the front off the machine and removed the temperature sensor and the spade clip-on wires. Also removed the nut in the centre over the earthing strap connector. What is next? Is or are there nuts and bolts to remove from the rear of the machine perhaps?
Many thanks for your advice. Laurie
Re: Bosch WFL 2860 – How to change the water heater
Many thanks – after quite a lot of gentle persuation it did leave the machine. I’m in the hardest water area known to mankind and what the heater had collected proved this convincingly. Regards,
Laurie
