Bosch WFL2000 no rinse or spin not everytime
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WFL2000 no rinse or spin not everytime
  • #53025
    talkingtent
    Hello I have this Bosch wfl2000 it will sometimes fill not always also when you select spin will not always spin every time. The pump cuts in for a couple of mins then back to end on display. Have checked brushes and fitted another pressure switch all ok. anyone??
    #314105
    nomadPaul
    Hve you checked the pressure chamber at the bottom rear of the tank ?
    #314106
    talkingtent
    Re: Bosch WFL2000 no rinse or spin not everytime
    Checked pressure chamber all clear. Do you think it is the board can’t always select a program ?
    #314107
    talkingtent wrote:Checked pressure chamber all clear. Do you think it is the board can’t always select a program ?
    I would think that the heater is the guilty party here?
    A faulty heater gives symptoms such as you describe sometimes. 😉
    #314108
    talkingtent
    No earth fault on heater ? Stuck now ?
    #314109
    Doesn’t need to be an earth fault…just open circuit.
    #314110
    talkingtent
    No it not open circuit?? 😥
