Bosch WFL2000UK/01
  • #31097
    House breakers tripped. The main motor is badly goosed.
    What is the possibility that it has taken the PCB with it?
    Re: Bosch WFL2000UK/01
    iadom wrote:What is the possibility that it has taken the PCB with it?
    Very strong possibility I would think? And it’s a bit of a fiddle taking the board out just to inspect it I know, but that’s the only sure way to know I guess. 😕
    You could try disconnecting the motor and putting it on a drain only cycle, if that does it’s thing then the board may just be OK?
