Bosch Washer WFL2060/01, No drum action /not spinning. Customer said did fills & empty ok. So did not try the machine first went straight to motor as usual fault
Motor brushes worn right down, Replaced brushes and now the machine does not start up. you can select programe press start Active light comes on door energises but wont do anything on any programe.
Is this a PCB fault, board looks ok apart from it covered in carbon dust.
Cheers
Steven
