Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch WFL2060 still having problems
- This topic has 4 replies, 3 voices, and was last updated 20 years, 5 months ago by
cornflakes.
October 29, 2005 at 3:37 pm #12913
cornflakes
Participanthave visited this machine this morning
problems found:
1] select spin cycle, machine fills!!!! and acts as if its is in rinse cycle
2] select wash 60 degree, water in – runs for 2 minutes-then stops completely.
3] select spin second time- pump kicks in -runs for 45 secs-stops-no further action.
4] select other wash options- water in for 40 secs- then stops
have checked pressure switch- 2 stages when blown into. with pressure pipe removed prgrammes irratic
any ideas welcome
graham
ENR-wfl2060gb/12
October 29, 2005 at 9:32 pm #152220Dave_Conway
ParticipantRe: Bosch WFL2060 still having problems
A bit of a long shot but I don’t suppose the linking plastic part between the knob and the PCB has been damaged or fitted incorrectly has it ?
It sounds like the programme dial is in the wrong position somehow 😕
October 30, 2005 at 7:59 am #152221Martin
Dave_Conway wrote:It sounds like the programme dial is in the wrong position somehow
Wouldn’t think so Dave and easy to realise if the 12 o’clock “Off” position wasn’t OFF anyway. So most likely its either the motor or heater at fault causing the programme to shut down OR the timer/module unit is duff. 🙁
October 30, 2005 at 11:46 am #152222cornflakes
thanks guys
was expecting a suspected timer… as each programme selection varies when selected a second time, nothing is constistant with fault pattern
any idea of cost new timer unit,machine is just under 3 years old so might be worth saving from the tip
Graham
October 30, 2005 at 11:57 am #152223Martin
cornflakes wrote:any idea of cost new timer unit
Yes it’s part no: 432218 and fits a few different models too. I’ve fitted just one so far and the fault with that one was that the double pole switch on the rotary switch had dodgy burnt terminals. (So yours could be the same sort of fault maybe?)
Module (retail – including VAT) currently is £101.05 🙁
