Bosch WFL2062GB/12
  • #52884
    ray.t
    Hi Been to this today.
    Problem is that if you select drain only, the pump will work for about 5 seconds then the light on display goes back to ready.
    If you select spin the machine works fine pump working all the way through.
    I checked the carbons and they were low but still ok as customer said she has had a problem getting the machine to spin.
    Cheers, Ray
    #313505
    Re: Bosch WFL2062GB/12
    Drain only ending after a few seconds sounds to me like there’s an earth leak on the heater? I would megger that heater, check that the air chamber isn’t clogged and replaced the carbons whilst your at it! 🙂
    #313506
    ray.t
    Thanks for that I will check it out.
    Cheers, Ray
