Bosch WFL2062GB – Inner drum out of alignment
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WFL2062GB – Inner drum out of alignment
  • #80382
    tubafan
    An issue with my mother’s old WFL2062GB.
    She initially reported that the machine was screeching and that the drum seemed tight when turned by hand.
    She had a repairman out who diagnosed a perished drum collar and replaced it, but this has made no difference.
    I have now taken a look and found that the inner drum is not sitting square in the outer one – when turning the drum the gap at the front between the inner and outer drums changes by about 5mm at the bottom as it turns. There is no play in the bearings though.
    This misalignment is causing the inner drum to rub on the collar – hence the screeching noise and tightness.
    The only cause I can think for this is that the drum spider is bent or broken, but would like some more opinions please.
    #412641
    Re: Bosch WFL2062GB – Inner drum out of alignment
    You are probably correct in that the inner drum support spider has failed. (One arm has probably corroded and snapped) 🙁
    #412642
    tubafan
    Martin,
    Thanks for confirming my suspicions.
    As this is probably uneconomic to repair given its age are there any suggestions for a not too expensive (£300- £400) replacement?
    She just needs something basic and functional that will hopefully keep running for a few years.
    #412643
    Another Bosch your best option, which one? don’t ask just go as far up-range as you can afford. 😀
