Fittng one of these board for the first time. Have found the S1 switch bank (8 switches) on the PCB but the instructions for coding also refers to switch bank S10 (2 switches) which I cannot see on this board. Am I blind or have they done away with this switch? 😕
Also the old board had blown at the relays but no earth fault on motor or element. Does anyone know the resistance reading for the motor pins?
Any other suggestions for the blown board would be good as I could be out of pocket by monday night 😥
Looking forward to some help.
Thanks Graham
Found switch S10 in the end it was covered in a clear lacquer type material that made it difficult to see. The 2 switches that are built into S10 were set correctly for this model.
All up and running.
Thanks for the help.
Graham
