Bosch WFL2066 washer
  • #72059
    Muv
    Hi all
    Had a look at this machine today..no spin fault initially, so started to take brushes out for a look..they were fine…whilst under the machine,I stuck my magnetic LED lamp to the inside of machine..(very handy bit of kit). Whilst it was all nicely illuminated I spotted the element…
    All it’s connectors burned and even broken off!
    Is this a common fault with these machines?
    and is it likely to be either the NTC, pressure switch, or relay.. That was the cause of it..
    Hopefully it has not done to much damage to the outer plastic drum..as I have not attempted removal yet…thought I’d first ask on here if anyone has come across this before..
    Re: Bosch WFL2066 washer
    Muv wrote:Is this a common fault with these machines?
    Very common fault in fact. Loose spade terminals the usual cause. Looks like in your case the NTC harness (part no: 423704) may also need replacing as well as the NTC itself (170961) and the heater of course. 😉
    #383244
    Muv
    Thanks for the advice Martin.. Much appreciated
    don
    Hi Muv
    Can you please post Technical questions in the Trade tech forum please.
    Moved to Trade Tech forum.
    Don
    PS This one is for Martin :clown:
    #383246
    Muv
    Yes no probs, sorry
    M
    #383247
    Muv
    Have now replaced all parts, apart from the NTC Harness, which is still lost in post!
    Have put on to test, but cant get any motor action, will these machines fail to turn if the NTC is not connected…? Brushes are fine, machine worked ok before..
    Muv
    Sorted…
    Dirty connector in motor plug!
    M
    #383249
    Muv
    Does anyone have a Manual for this machine please… either original, or PDF
    Muv
    Anyone?
    Muv
    Its ok, found it on the bosch site
