Bosch WFL2066GB
  • #32591
    leginjc
    I have a Bosch 1000 Model No: WFL2066GB/08 – FD8410603461.
    The machine will go through the wash cycle but will not drain and so will not rinse or spin. So far, having read /searched this forum I have checked the following:
    1 removed and checked that the filter and all drain hoses are clear.
    2 ensured pump is working, by running the spin cycle with filter cap off and seen pump turning.
    3 checked motor brushes which appear virtually new.
    I got the machine second hand from a known source and know that it has had very little use until I got it since when it has been used about 3 times a week for family washing for about 6 months.
    Any ideas as to what the problem maytbe would be gratefully received.
    #235719
    gegsy
    Re: Bosch WFL2066GB
    Check where the drain hose is terminating ie- sink spigot etc
    Try aiming drain hose into bucket and see if it empties 😕
    leginjc
    gegsy wrote:Check where the drain hose is terminating ie- sink spigot etc
    Thanks Greg will give it a go and report back.
    Nigel
