Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch WFL2066GB/08. lights flashing
- This topic has 12 replies, 4 voices, and was last updated 17 years, 11 months ago by
iadom.
April 18, 2008 at 1:10 pm #36122
ModeratorCustomer just rung, machine ended last wash without taking conditioner, now will not start, Rinse Plus & Wash Plus lights flashing.
Going on Monday morning, any pointers?
April 18, 2008 at 1:32 pm #249632boselecta
ParticipantRe: Bosch WFL2006GB/08 lights flashing
WFL2006 does not exist, dont think that is the right model no, there is a WFL206?, sorry no help there then.
April 18, 2008 at 1:42 pm #249633Martin
iadom wrote:Customer just rung, machine ended last wash without taking conditioner, now will not start, Rinse Plus & Wash Plus lights flashing.
My guess is that it’s a WFL2066GB/08 and that the Wash LED flashing usually indicates a door interlock problem? Also Heater open circuit another possibility?
April 18, 2008 at 1:52 pm #249634iadom
ModeratorRe: Bosch WFL2006GB/08 lights flashing
Could be my dodgy writing 😳
Will suck it and see on Monday. 🙂
April 18, 2008 at 11:23 pm #249635gegsy
Heater borked 😉
April 19, 2008 at 5:16 pm #249636iadom
Thanks for the ‘stuff’ Greg, 😉
April 19, 2008 at 5:20 pm #249637gegsy
You welcome 😉 erm sorry bout the other stuff 😆
April 21, 2008 at 3:02 pm #249638iadom
ModeratorRe: Bosch WFL2066GB/08 lights flashing
Deffo not the heater.
As stated in the first post which you all read carefully didn’t you, :rolls: 😉 🙂 the lights that are flashing are ones above the wash PLUS & the Rinse PLUS option buttons, not the vertical row of programme follower lights.
Heater, motor, valves, pump, doorlock etc all appear OK.
It will not go into test mode, all that happens when you select any programme is those two lights flash rapidly. I suspect it may be the PCB. 😥
Unless you know different. 😉
April 21, 2008 at 7:22 pm #249639gegsy
ParticipantRe: Bosch WFL2066GB/08. lights flashing
If we had correct model number as the /?? is important :rolls: 😉 We could always blame Martin for the wrong info as he suggested it was an /08 😆
WFL2066GB/06 is different from the /08, so assume below 😉
Fault on this model would be indicated in display F0 etc.
I would now assume PCB fault if lamps are flashing.You have mail 😉
April 21, 2008 at 8:08 pm #249640iadom
ModeratorRe: Bosch WFL2066GB/08. lights flashing
Wrong model number was my fault initially. It is definitely an /08.
I had posted WFL2006 in error but the 08 bit was right. 😳
I edited my original post. 😉
I have saved the /06 stuff for future use, thanks for that Greg.
So as this is an /08 version does it sound like a duff PCB? 🙂
April 21, 2008 at 8:30 pm #249641gegsy
Certainly sounds like it Jim 😉
April 21, 2008 at 8:39 pm #249642iadom
The really sad bit about this is that this customer had a Hotpoint for over 15 years and still has the Hotpoint dryer of the same age.
Before I had a look at the machine she said my husband wants to get a new Bosch dryer when that goes, he likes the high quality German machines. :rolls:
This one is under 3 years old.
I will give her the bad news. 😥
PS. Can you confirm that 438749 is correct part number.
May 13, 2008 at 5:12 pm #249643gegsy
iadom wrote:PS. Can you confirm that 438749 is correct part number.
Yes it was but has since been changed to 443356
HTHGreg
