Hi, this washer has no display most off the time,the odd thing is the custormer can use it sometimes,but after 1 wash which works fine the display goes,and has to wait 4-5 days and then display lights up an 1 wash can be done,I’ve seen the thread about dry solder joints and checked an resoldered the ones in question,any ideas would be great,cheers
Yes sorry it does have LEDs,the problem is you can set washer to wash an LEDs light etc and you can do that 1 wash,after tho if you try to select another program the LEDs won’t light an the machine will not work,weird thing is if you leave it off for 4-5 days and try again it will wash once more then same no led/start problem
It sounds like the switch contacts on the rotary switch (on the control board) are arcing. You can inspect and clean them up sometimes though access is limited.
