bOSCH WFL2067gb/16
  • #44170
    johnnyj
    I’ve just been to a Bosch wfl2067gb/16 customer was complaining of spin light flashing and not working correctlty, her hanbook states check filter etc, i’ve checked brushes heater etc it wont fill on main wash but drum agitates if i turn to rinse it will fill and spin i suspect it may be a pressure sw fault anybody come across this before JJ
    #280033
    Re: bOSCH WFL2067gb/16
    Take the sump hose off and check the ball valve and pressure chamber?
    #280034
    johnnyj
    Hi Martin i disconected the press hose from the level sw and it was still misbehaving, so i assumed the sump would be okay thats how i was thinking press sw or module maybe, jj
    #280035
    nomadPaul
    Are both valves working ?
    Only one valve is used for main fill but both are used during rinse fill .
    Maybe its filling on rinse from only one valve ?
    #280036
    I can only think that it must be the pressure switch then if it tumbles on wash without filling? I guess the heater has burnt out too in that case?
    #280037
    johnnyj
    Checked the heater it is okay but i’m going to go back and have another crack at it cheers guys
    #280038
    lerch
    Also check ntc as some bosch do a self check upon starting.
