Hi guys been at a Bosch washer not heating and sticking on programe i’ve checked the element and it tests okay, i’m suspecting the module as the cause has anybody else come across this cheers JJ
Almost certain to be a module solder joint relay problem. Tricky to access but your only option. Once you get the module out and before you take off the covers just double check the heater connection at that module end before switching on the soldering iron. 🙂
