Bosch wfl2260 active light
  • #53207
    cornwell40
    No obvious faults on the machine (other than an old dear desparate to find a fault with it) other than when the wash ends the active light stays on after the door has opened, but will reset to ready once the dial is turned off. Works and sounds fine otherwise. Any ideas 😕 ?
    TC
    #314852
    gegsy
    Re: Bosch wfl2260 active light
    IIRC the active lamp stays lit for a while after door unlocks.
    If doesnt go to readty,possible coding/module error.
    cornwell40
    Should it not go to end 😉
    TC
    #314854
    gegsy
    Yea after a period after door unlocks and ready if you switch off then back on 😉
