Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch WFL2260 bearings
- This topic has 9 replies, 3 voices, and was last updated 19 years, 10 months ago by
robmarshall.
May 30, 2006 at 7:08 pm #18160
robmarshall
ParticipantMy washing machine, although working fine and not making any nasty noises, has developed a “up & down” play in the outer drum.
Machine does 1 wash a day approx and is not overleaded.
Are bearings known to die on this model, and if so, is it tub removal & split in two job?
While I’m here, anything else prone to go wrong with this model since it seems a bit of a “cheapy” in Bosch’s range.
Any advice / experience gratefully received!
ROb
May 30, 2006 at 7:25 pm #177967gegsy
ParticipantRe: Bosch WFL2260 bearings
Hya Rob
Yes it is a split tank, but isnt for the faint hearted. Its not the easiest of split tanks. Personally I would seek an engineer for this one.
As for the other points raised, they are a pretty good machines and rarely give problems.
How old is it anyway??Greg
May 30, 2006 at 10:25 pm #177968robmarshall
built in 1999 I think
May 30, 2006 at 11:08 pm #177969gegsy
Thats not bad for 7 years really. Wouldnt get that sort of durability from the run of the mill junk we see about today.
I think they are good value for money compared to most IMO.
GregMay 31, 2006 at 8:26 am #177970robmarshall
The guy I bought it from said it was “hardly used” thanks to him moving out and storing the machine due a a divorce, so I was hoping to get a few more years out of it yet!
May 31, 2006 at 9:03 am #177971Goatboy
The bearings could go faulty prematurely, if the machine was installed incorrectly. 🙁
That drum is normally pretty reliable!
May 31, 2006 at 2:02 pm #177972robmarshall
HOw would that happen may I ask?
May 31, 2006 at 2:51 pm #177973Goatboy
If all four feet aren’t firm on a solid floor, making the machine level, then the all the stress during the final spin, won’t be exerted in the right places.
Whenever I’ve seen premature bearing failure on a plastic tub Bosch, that’s been the common factor.
May 31, 2006 at 3:56 pm #177974robmarshall
Blimey! NO al feet are on the ground!! Just hope it doesn’t get worse very quickly! Should there be a little bit of play at all?
June 1, 2006 at 10:15 am #177975Goatboy
robmarshall wrote:Should there be a little bit of play at all?
Nope 🙁
Maybe the guy you bought it off, used it more than he said?
