Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch wfl2260 conditioner not being used
- This topic has 7 replies, 6 voices, and was last updated 20 years, 11 months ago by
rbn.
May 9, 2005 at 7:32 am #9460
rbn
ParticipantWhen I place conditioner in the detergent dispenser tray on my Bosch wfl2260 it is not used during the wash cycle. I have removed the tray and cleaned it and the area behind it. What else should I look at? Where else might there be a blockage or problem?
RobinMay 9, 2005 at 8:02 am #134167Martin
ParticipantRe: Bosch wfl2260 conditioner not being used
Remove the drawer then clean the four holes in the dispenser cavity above the drawer. (They usually get blocked with a bacteria build-up!)
May 9, 2005 at 9:10 am #134168gegsy
Also low water pressure will cause this aswell.
GregMay 9, 2005 at 10:06 am #134169Goatboy
I sell alot of that model of Bosch, and I’ve had this complained alot!
The problem seems to be the thickness of modern conditioner. By the time the machine wants to use the conditioner, it has set into a mass of jelly and the water just runs straight off it, or picks the conditioner up in a solid lump and runs undernealth it.
The solution? Just dilute the conditioner with a small amount of water. This always solves the problem for my customers. 😉
Edit – Always shake the bottle first as well!
May 9, 2005 at 3:55 pm #134170eastlmark
ModeratorRe: Bosch wfl2260 conditioner not being used
Bosch use a double cold valve that may be one half duff or the dispenser top section may need replacing if blocked internaly. Neither are an expensive job but it is one for an engineer.
click here to try our repairs@ serviceMay 9, 2005 at 7:46 pm #134171superfix
Martin wrote:Remove the drawer then clean the four holes in the dispenser cavity above the drawer. (They usually get blocked with a bacteria build-up!)
Poke a cable tie into the four holes in the middle of the dispenser.Then run through rinse cycle a few times.
May 10, 2005 at 3:22 pm #134172rbn
Thanks for all the responses. It turns out that poking a wire up the four holes above the dispenser was what was required.
Robin
May 10, 2005 at 3:29 pm #134173Martin
Thought as much…. 😉
