My Bosch WFL2260 has just started leaking. Part way through the fill cycle water starts to form a puddle under the machine. It seems to be leaking from the bottom near the front somewhere.
I removed the top and looked underneath too. The top is bone dry (around the inlet) so I don’t think it’s that.
I can’t seem to locate the source of the leak – it comes out quite fast so I would have expected the origin to be easy to find. The drain pipes seem fine and it does not leak if I manually fill the machine and then run the drain programme.
(I did remember to switch off the power) 🙂
Can anyone offer any advice please? I guess the most likely cause is a split in the door seal but it looks OK on inspection.
Mark
