Bosch WFL2260 motor
  • #57063
    M1
    This motor kicks on spin a few times.
    Changed Brushes & Changed PCB same problem.
    I think its loosing tacho feedback & switching the motor off.
    Main motor coil 1.7 ohms Good.
    Con check through brushes Good.
    Tacho Coil 15 ohms Good.
    Tryed spinning motor but don’t get any milli volts out of tacho coil.
    Do the tacho magnets fail ?
    #329687
    Re: Bosch WFL2260 motor
    M1 wrote:Do the tacho magnets fail ?
    The WFL2260UK and WFL2260GB versions use either a Siemens motor or and FHP motor. Which one do you refer to I wonder? The Siemens ones don’t usually have tacho probs though I have had one in the past where the magnet broke up. FHP motors can have tacho coil issues but rarely in my experience.
    Connector block wires can play up and break especially if the harness isn’t clamped with cable ties to the motor body.:wink:
