BOSCH WFL2260UK/01 w/m
  • #15895
    mike412
    Morning All.
    Put a new door boot on this yesterday, all seemed ok. Customer reports this morning that he cant change programmes and the “activity” light is flashing.
    Any ideas what this means?.
    Mike
    #166693
    superfix
    Re: BOSCH WFL2260UK/01 w/m
    Did you remember to plug the door lock back in I wonder 😳
    #166694
    Beever
    If you had forgotten to plug the door lock back in you would have the ready light flashing.
    The active light flashing indicates that the inlet tap is closed, or the water pressure is less that 1bar @ inlet valve. IE pipes kinked, or strainer is blocked
    #166695
    mike412
    Thanks Beever.
    You answered my PM before I sent it- You must be Psychic!.
    Cheers,
    Mike.
    #166696
    Beever
    Any probs let me know but that should sort you out!
    #166697
    Beever
    How did you get on with the bosch maxx WFL (active light flashing after replacing the door seal?)
    Regards
    Ian B
    :martin:
    #166698
    mike412
    Hi Ian,
    Thanks for your interest.
    I did not have to visit in the end. THANKS to the fault code you supplied I was able to deduce the problem. After completing the repair and testing I had left the machine out of its location to allow the customer to do a bit of very necessary cleaning. On putting the machine back in situ he had trapped the filling hose. Quick phone call- SORTED!.
    Many thanks once again,
    Mike.
