Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch WFL2260UK/04
- This topic has 10 replies, 5 voices, and was last updated 15 years, 7 months ago by
robbra.
August 26, 2010 at 4:39 pm #56819
robbra
ParticipantHi,
changed the brushes but nothing apart from fill and empty. Motor measures out ok. Pcb clicks as per motor changing direction so took the PCB off and nothing visible. Continuity ok on wires from the PCB to motor.
Am I missing something or is it the PCB which I think is very unusual?
RobAugust 26, 2010 at 9:52 pm #328963peterjay
ParticipantRe: Bosch WFL2260UK/04
check main board
poss relay or track blown
also check for dry solder joints on motor relayAugust 27, 2010 at 6:52 am #328964robbra
Thanks Peter,
Tried all that but nothing visible and as the PCB is over £200 I think it’s a BER.
RobAugust 27, 2010 at 7:02 am #328965Martin
Defo PCB 😥
August 27, 2010 at 9:37 am #328966leavemetogetonwithit
If customer can wait for a couple of days (I know that’s the difficult bit), and you have the time, why not do a few simple tests on the pcb yourself? If brushes going down caused this, which is likely, then you could just be looking at replacing motor triac or perhaps a relay; both easily checked. If you find something, and repair it, you get a buzz and you charge appropriately for your expertise.
Mike.August 27, 2010 at 11:45 am #328967Martin
leavemetogetonwithit wrote:If brushes going down caused this, which is likely, then you could just be looking at replacing motor triac or perhaps a relay; both easily checked.
Ah…now that’s where I would be less than confident, or competent even, attempting. Whilst it’s fairly easy and obvious that a triac has blown by the simple fact that very often you see the plastic lid blown off! It’s less than easy to suss out the value or its replacement reference number to then source a replacement. Let alone fiddle about desoldering/resoldering in a tiny little component with my welding rod of a soldering iron, my one good eye and very shaky hands. 🙁
How the hell you test that a relay has failed god only knows? Apart from the obvious burnt relay pins that is. I’ve re-soldered those pins successfully more times than Gandhi had a hot dinner but if the pins ain’t burnt, I’m at a total loss.:cry:
One thing I’m well in front on though is that I stock a good range of BSH modules that I’ve bought DIRT CHEAP or at some point in time have fallen off a passing lorry. Speculating all the while that at some point in time there will be a demand to replace rather than wrestling with the above scenario! 8)
August 27, 2010 at 12:05 pm #328968leavemetogetonwithit
I bet you don’t have the one Rob needs.
I’ll put some info. on relay testing in pcb repairs thread soon.
Mike.August 27, 2010 at 12:47 pm #328969Martin
leavemetogetonwithit wrote:I bet you don’t have the one Rob needs.
Oh yes I have……!!! 8) 432218 is the part number and I have one right here in my high security stockroom just waiting for the right offer. 😉
August 27, 2010 at 3:31 pm #328970nomadPaul
I bet you don’t have the one Rob needs.Oh yes I have……!!! 8) 432218 is the part number and I have one right here in my high security stockroom just waiting for the right offer. 😉
Afternoon DelBoy…..lol 😆
August 28, 2010 at 9:55 am #328971robbra
Thanks for all the info but by the time I got back to her she had gone to Comet and picked up a new Bosch. Tried the ISE line but just too late 😥
RobAugust 28, 2010 at 1:31 pm #328972Martin
robbra wrote:Tried the ISE line but just too late 😥
Gone cold by then I expect? 😉
I’m sure you’ll be back to unpack and install the new Bosch though. Whenever I BER a machine I always volunteer my expert ‘installation and demonstration’ services at a modest ‘call-back fee’ so all is never lost to those darn sheds! 🙂
