Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › bosch WFL2260UK/04 FD 8005 609230
- This topic has 9 replies, 2 voices, and was last updated 19 years, 1 month ago by
wishbone.
February 22, 2007 at 6:28 pm #25293
wishbone
Participanthi, went to this today and clean out pressure system also filter etc.
checked inlet valves and left on test.
customer has phoned back to say it does wash okay but seems to skip rinses, then spins and ends with light flashing. going back tomorrow to
have another look. anyone had this before ?
any ideas much appreciated..
thanks pete.February 22, 2007 at 8:01 pm #205260gegsy
ParticipantRe: bosch WFL2260UK/04 FD 8005 609230
Will need to know what lamps are lit and/or flashing.
You could check the fill valves :con:
In what way does it skip ask her, she may just be using too much powder,leaving residue and making her think its not rinsing 😀Greg
February 22, 2007 at 8:20 pm #205261wishbone
hi greg, checked the fill valves, all okay.
she said went through cycle quicker than normal and ended with one light flashing, dont know which one. going back tomorrow, is there error codes for this model, couldnt find them in known error codes list….
(only three lights on this model)February 22, 2007 at 8:27 pm #205262gegsy
Check your email 😉Greg
February 22, 2007 at 8:53 pm #205263wishbone
thanks that should help, how do you run the service programme ?
February 23, 2007 at 8:24 am #205264wishbone
HELP calling back to this afternoon for another look.
greg sent me the error codes but you need to run the service
programme (also for last error) how do you start the test/service programme on this model ?
thanks pete…..February 23, 2007 at 11:06 am #205265gegsy
Sorted now, check email 😉Greg
February 23, 2007 at 1:05 pm #205266wishbone
Thanks Greg…..
February 23, 2007 at 11:52 pm #205267wishbone
called back today, no supply to inlet valves on rinses.
connector to valves looked a bit burnt so cleaned up and checked
back to connector at control board which tested okay.
guess fault on control board but customer decided to replace
machine.
thanks for your help
pete….February 23, 2007 at 11:53 pm #205268gegsy
No probs Pete , you’re welcome
