Bosch WFL2450
  • #35690
    Latham63
    Have a problem with Bosch Quickwash option.The quickwash light illuminates ,suggesting it is selected, but the wash cycle operates on a normal cycle which is an hour or so longer. I suspect the control board is faulty.Any ideas??
    #247621
    Is that not one of the fuzzy logic ones? If it is then it will speed the cycle up but perhaps not complete it as fast as you want.
    The usual advice applies, if it completes the cycle correctly then there is in all probability no fault.
    HTH
    timdowning
    Re: Bosch WFL2450
    Could be the heater is at fault.
    #247623
    Latham63
    Re: Bosch WFL2450
    [q
    uote
    =”timdowning”]Could be the heater is at fault.
    Thanks Tim, it was the heater.Stumbled upon it by accident whilst replacing the pump!
