Bosch WFL2450 – drum won’t turn
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WFL2450 – drum won’t turn
  • #27985
    anamorphosa
    Dear Forum,
    I have a Bosch Max WFL2450, approx 6 years old. All fine till this morning; now the drum won’t turn (on any programme).
    It does fill and drain happily, just not turn. The controller board “clicks” when it’s trying to turn on the motor, so I think it’s the motor not the board. I’ve had a look at the motor, and there’s no obvious electrical issue (i.e. not charred or missing connections). From what I’ve read, the brushes could have worn out; how can I tell whether this is true, or where else the fault might be?
    Thanks in advance,
    David
    #216408
    Re: Bosch WFL2450 – drum won’t turn
    You will need to use a test meter to check for continuity across the armature. If you have no reading, you’ll need a pair of these:
    http://shop.ukwhitegoods.co.uk/product_ … cts_id=435
    Power off, of course.
    anamorphosa
    Wow, that was quick!
    Where should I take the reading? I’m not sure which of the 6 or so orange cables in the connector block connects to the armature, and I’m not sure how to take the motor off/apart.
    Are there any service manuals or similar that would show me?
    Thanks,
    David
    #216410
    gegsy
    http://www.ukwhitegoods.co.uk/modules.p … pic&t=4359
    If you are unsure, of where to measure from then I would just remove the brushes and inspect, they are approx 1.5 inch in length when new. If they are much lower than that then follow P45s guide to spares 😉
    Unplug appliance if you are to investigate :plug:
