BOSCH WFL2450GB/01 heater?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum BOSCH WFL2450GB/01 heater?
  • #52897
    johnmac
    The heater is open circuit. I can see that the bolt and the terminals are easy to reach from below, but can anyone tell me if there’s room to get the element into its hole, or do I need to take the front off the machine?
    The machine is 9 years old, so I’m thinking I’ll bin it if this is a difficult job?
    #313554
    Re: BOSCH WFL2450GB/01 heater?
    Front panel off – 2 screws at the bottom, one in the soap drawer opening. Slip band from door seal and release it, whole thing will come away.
    johnmac wrote:
    The machine is 9 years old, so I’m thinking I’ll bin it if this is a difficult job? :rolls:
    Why on earth would you ‘bin’ a perfectly good machine just because it needs a heater? Even if you had to get a pro in to repair it it would make more sense than throwing it out. You would have to spend in the region of £450 to £500 to get something as good.
    Front panel comes off easily enough, screw behind soap drawer, and screws along bottom edge, release door seal retaining wire and door interlock and the front comes off in under a minute.
    #313556
    Evening P45. 8) :waving:
    #313557
    johnmac
    OK, point taken, it is a good machine. Thanks.
