Re: Bosch WFL2450GB/01 – not empting at end of wash
I would change both valves IMHO
If as you say it keeps filling even when not powered up then its definately one of the water valves staying open. If you don’t want to change both, the best way to deduce which one is at fault is to turn of the feed tap to each fill hose in turn to see which stops it filling.
Parts are as follows,looking from the rear of appliance, l/h valve is p/no 428212 and the one next to it is p/no 428210. Both spares are available from spares@ukwhitegoods.co.uk .Around the £10 – £20 each plus the usual.
Power off if you are to attempt the repair.
