Bosch WFL2450UK/12 No heat
  • #30792
    clayside
    Have a WFL2450UK/12 had hose off dispenser which sprayed water over electronic, dried it out machine then had no heat. Fitted new electronic checked heater, pressure switch & wiring still no heat.Can only think NTC
    is faulty. What happens on this machine if NTC goes off range, would it cause this fault. Regards clayside
    #228480
    gegsy
    Re: Bosch WFL2450UK/12 No heat
    If the NTC goes out of range etc, the machine will NOT abort but will continue as normal washing in cold water 😀
    NTC p/no 170961 around £6+ VAT
    clayside
    Fitted new NTC machine seems fine now, thanks for help. clayside
    #228482
    gegsy
    Excellent :tup:
