Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › bosch wfl245s program problem
- This topic has 10 replies, 2 voices, and was last updated 13 years, 2 months ago by
patchitos.
January 25, 2013 at 8:46 pm #73759
patchitos
Participanthi…i’m hoping someone can give me a clue…..i just replaced the bearings on a bosch wfl245s w machine as the belt was coming off…on the following first wash it got about 20mins into the cycle when it went into a fast spin for 1-2 seconds then stopped!now when i start a cycle it fills as normal then starts to spin fast for a couple of seconds then stops….if i leave it on…it seems idle but every 2mins or so it will start a fast spin for a couple of seconds…i don’t want to scrap it as i just spent ages doing the bearings….any help would be much appreciated…thanks…john
January 25, 2013 at 8:57 pm #388700Martin
ParticipantRe: bosch wfl245s program problem
The wire connection to the tacho generator on the motor is broken or the tacho magnet inside the motor has cracked.
January 25, 2013 at 10:31 pm #388701patchitos
thanks martin…..i’ve just looked inside the motor..nothing visibly broken….which part is the tacho generator? i’m assuming i can take the motor somewhere and get it tested properly? thanks for your help…john
January 26, 2013 at 8:01 am #388702Martin
I figured that being as you replaced the drum bearings, most likely the motor worked OK before? Then logically you must have damaged a wire getting the motor off? On that basis then just look for a broken wire connection…….. 💡
January 26, 2013 at 9:30 am #388703patchitos
ok martin……i’ll have a good look and let you know how i get on….thank you….john
January 26, 2013 at 4:01 pm #388704patchitos
hi martin…..no broken wires…i was thinking that as the machine started the cycle and then behaved normally for at lease 20mins.when it then suddenly went into a fast spin for a few secs – at first i thought it was the belt coming off again…maybe it’s just coincidence that it’s gone wrong just after changing the bearings….i’m thinking i should try a different motor…what do you think?….thanks…john
January 26, 2013 at 4:10 pm #388705Martin
patchitos wrote:….maybe it’s just coincidence that it’s gone wrong just after changing the bearings….
I still don’t think so. If those wires on the motor connector block have been strained in any way then the symptoms tell me there’s a loose wire there somewhere. Motors are expensive but a new wiring loom costs less than a tenner!
January 27, 2013 at 12:22 pm #388706patchitos
ok martin….one of the wires did pull out fairly easily from the motor connection block!..although not really loose(an end one-bottom)…i need a new wiring loom now anyway…doesn’t seem to be on spares list so i’ll make a spares inquiry in the morning…..i’ll be impressed if you’re right…..i’ll let you know….thank you very much….john
January 27, 2013 at 1:45 pm #388707Martin
patchitos wrote:doesn’t seem to be on spares list so i’ll make a spares inquiry in the morning…..
The Motor Cable Harness (part no. 172694) available from the Bosch site ( price £27.26 though :()
February 12, 2013 at 6:17 pm #388708patchitos
hi martin..AAA+++..yes….you’re a genius……i fitted a used cable harness today…haven’t plumbed it in properly yet but the spin cycle works perfect…..i would never have worked out the problem without your help….thank you very much….john…
February 12, 2013 at 6:42 pm #388709Martin
No probs, my pleasure! 😀
