Re: Bosch WFL245SGB/04 Does not spin
Hi Terry
If you are profficient in the use of a multimeter, you could check the motor pin resistances.
Between:-
Pin 2 and 3…. 0.8 ohms – 2 ohms
Pin 4 and 5…. 4 ohms – 10 ohms
Pin 6 and 7…. 14 ohms – 240 ohms
:lesson: Please note these readings will be obtained with the appliance unplugged :plug:
If that checks out the wiring from motor to module for continuity.
If in any doubts, please feel free to use the engineer link below.
