no fill, took a double bosch valve to try no joy, checked pressure pipe etc. no error code, blew into pressure switch and tested with multimeter for a closed circuit at and seems ok,
my gut says pressure switch still? checked timer/board behind facia and no blown or burning at all?
it will pump etc, very similar to no supply or valve dead.
That’s unusual. It’s always been a solenoid down when I’ve had this on a Bosch 😕 . One thought occurs to me from the enormous number of hours I’ve spent reading posts on here, and it could be an absolutely ridiculous suggestion but I seem to remember some connection between worn down brushes and no fill on certain machines. Could be worth a look if no one comes up with a better answer.
Mike.
cheers guys never occurred to check the brushes, from what i can remember the drum dident move at all, it seemed to pulse the valve at one point almost like a loose connection.ill take another look and keep posted.
