Water not heating but progresses through cycle as normal.
Element ok, PCB visually intact and wiring from element back to pcb and presure switch ok.
From quick search I believe this my be a NTC fault, it’s reading 8k ohms, is this within range please?
If it were a heating type fault then the programme would take at least an hour or even more longer to complete any cycle. But you say it “progressess through as normal” which is rather odd to say the least. 😕
If it does in fact take a lot longer than normal yet the heater checks out OK then it’s got to be the PCB. NTC’s don’t usually give this fault, in fact they rarely fail as a rule.
