Bosch WFL2463GB/?? Motor re-assembly.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WFL2463GB/?? Motor re-assembly.
  • #41175
    This motor has been eating brushes every 18 months or so. I last renewed them in May, then got called today to “no spin” fault. It seemed to work OK to me but motor was sparking a bit excessively. Decided to remove it and give it a much needed clean-up. Noticed that after removing brushes there was a slight resistance and ticking sound from tacho end.
    Anyway took it apart and cleaned it all but on re-assembly the ticking/clicking sound is worse. It’s nothing to do with the commutator because I haven’t got the brushes back in yet. It’s not the bearing which is OK. The shim and the spring washer are both back in where they came from.
    I’m sure one or two of you can tell me exactly what is going on here and what the sound is and how I can sort it, saving me having to struggle for hours to figure it out myself.
    Cheers,
    Mike.
    #269033
    Re: Bosch WFL2463GB/?? Motor re-assembly.
    Cracked tacho magnet? Can cause rough running and jolting when reversing – guaranteed to eat the brushes.
    Thanks for the reply Chris.
    Turned out to be an edge of the plastic insulating sheet between the field coil and laminations had risen and was rubbing on the armature. I held it down with a bit of epoxy putty and all is well again. Cleaned commutator with comm stick and brushed out all the carbon dust and motor runs like new.
    Mike.
