Bosch WFL2860
  • #27849
    Laurie1947
    Great Machine for 6 years. Then suddenly all lights go out and stops mid wash. Found 3 tracks on PCB controller board blown. Any ideas what caused this? I’d change the board but don’t want same to happen again if fault is elswhere?
    #215858
    clivejameson
    Re: Bosch WFL2860
    Most likely culprits are an earthing element or the motor letting go…you need to check for insulation failure around the machine and give the drum a spin by hand to listen to the motor 😉
    #215859
    Laurie1947
    Re: Bosch WFL2860
    Hi Clive,
    I traced the blown pcb track to the heater sensor in the heater element unit and found that lime scale from a previously leaking door seal had dripped water into the plug. All now cleaned and the pcb track repaired with 5 amp fuse wire as a precaution. Motor brushes replaced – they had a few months left in them. Also refitted the Triac as others had said this was probably OK if pcb track to it was not blown – as was the case.
    All put back and now seems to be working. So far it has run 4 complete wash cycles at 30 and 60 degrees – heater appears to be OK to.
    Thanks for your encouragement.
    Laurie 😀
