Bosch WFL2860 W/machine – Not filling properly
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WFL2860 W/machine – Not filling properly
  • #19206
    JBarker
    Hi there
    Hoping someone can point me in the right direction…
    My w/machine just isn’t filling like it used to – i’ve looked at both hot and cold inlet pipes and washed them under a tap – looked fine.
    Any othe robviuos things I should check?
    Thanks in advance
    JB
    #182168
    Re: Bosch WFL2860 W/machine – Not filling properly
    Is there a problem with it other than that, like poor wash or lights flashing? If not then its probably not a problem. Often they fill higher on rinse and delicate programms so check it on another programme and see what happens. If its not filling as fast as it used to, the dipsenser top section may be blocked but its not usually an issue on these machines.
