Bosch WFLI2440GB overfilling
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WFLI2440GB overfilling
  • #55473
    daveg73
    Hi, went to this machine this morning, fills and stops, starts washing, fills some more, starts washing, keeps repeating this cycle.
    Checked for pressure hose leaks and activated pressure switch with short length of tube, still does same thing.
    Any help would be greatly appreciated.
    #324052
    RickT
    Re: Bosch WFLI2440GB overfilling
    Have you tried blowing into the pressure switch via the tube, plugging the tube and waiting for the click?
    #324053
    daveg73
    Yep, done that,clicks immediately. if you blow and hold when machine is filling it stops filling and than starts again after about 5 seconds, release pressure and pressure switch clicks, so no pressure loss there.
    I take it the switch is single level?
    #324054
    nomadPaul
    I take it that you’ve checked the sump hose and pressure chamber underneath the tub for foreign objects and blockages ?
    #324055
    daveg73
    nomadPaul wrote:I take it that you’ve checked the sump hose and pressure chamber underneath the tub for foreign objects and blockages ?
    Did a rudimentary check, seemed OK, I assumed that manually operating the pressure switch would eliminate that possibility.
    Is there any sort of timed fill after the pressure switch has activated or other sensor connected with water inlet?
    #324056
    RickT
    Assuming that the water level is rising during this period of intermittent filling and not syphoning away, I would suspect pcb!
    #324057
    daveg73
    RickT wrote:Assuming that the water level is rising during this period of intermittent filling and not syphoning away, I would suspect pcb!
    I knew someone was going to say that 🙁
    Thanks Rick, I’ll tell the customer the good news.
    #324058
    Micky 32
    Maybe faulty presure switch? Bad contacts inside?
