Bosch WFLI2440gb10 ready light
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WFLI2440gb10 ready light
  • #55251
    Johnnyboy
    Customer swears it always goes from ready to wash and within 2 mins goes back to ready, I tried it 4 times and it was ok, any issues with this one???
    Cheers Johnnyboy
    #322425
    timdowning
    Re: Bosch WFLI2440gb10 ready light
    Did you take the front off the machine?
    Its worth checking the thermistor & connector as water contamination can give you this error.
    Oh and insulation test the heater while you’re there.
    #322426
    Johnnyboy
    good man I will do so when I return, cheers
    #322427
    Johnnyboy
    replaced heater had good result, Much later on still doing same but only when Im not there works fine when Im there. Is there a test prog or reset for programmer, customers voice could strip paint and she uses the Alex Ferguson “hairdrier” technique
    Cheers Johnnyboy
