bosch wfo 2865uk/01
  • #56766
    mikehha
    good evening gents .
    I have a m/c that sometimes takes 3-4 hours to go through a wash then it skips the rinses and gose to 1min on the display.Ifyou put it on to a rinse and spin it washes then gose to 1min if you put it on to a spin it dose the full 12 min .if you just try the drain it stops on 1min and stays there any ideas!
    mike
    #328768
    nomadPaul
    Hmmmm…..i’d be looking at either the heater or motor maybe going to Earth . You may in fact have more than a single fault . Poss open circuit heater and worn brushes . They are the 2 i’d look at first !
    #328769
    mikehha
    Re: bosch wfo 2865uk/01
    thanks paul
    first thing I thought of was motor so fitted new carbons and tested for earth fault also heater giving agood reading. mike
    #328770
    mikehha wrote:if you just try the drain it stops on 1min and stays there any ideas!
    By that do you mean you just select drain only with or without there being water in the drum? If the former it could be a drain time-out error and the later would indicate a faulty module most likely?:con:
    But as Paul says on it taking 3-4 hrs then skipping rinses then the motor and/or heater are the main suspects. Sticking just on a drain only cycle is a bit of an odd one there that I haven’t personally come across, yet anyway.
    Let us know the outcome please! 🙂
    #328771
    S1MON
    Ive had a clogged ntc cause a similar fault on the heater, it was completely covered in solidified powder residue and it was not reading during the wash……
