bosch wfo2064gb plastic tub dismantle problem
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries bosch wfo2064gb plastic tub dismantle problem
  • #18817
    bzz67
    does anyone know if its posible, or how to split apart the two tub halves on this machine,i need to clean the drum etc to stop it smelling.I have tried all the usual boil washes but no joy.The customer is willing to pay the labour cost but i cant find away to unclip those rediculous plastic clips.
    does this mean you have to change the whole tub and drum assembly if the bearings go!
    #180516
    Re: bosch wfo2064gb plastic tub dismantle problem
    I personally wouldn’t bother to go to such extremes to be honest. A series of boil washes using bleach based detergents will eventually solve the smell problem. But if you insist, then read this link : –
    http://www.ukwhitegoods.co.uk/modules.p … ic&t=15328
    #180517
    bzz67
    Thanks Martin.Already had the drum assembly out so i took it outside and flushed it through with a hose pipe.This worked well, and not too long a job.Cheers.
